Unable to make or receive calls
pcarsso
Hi, I am currently in Accra but unable to make calls or use data on my EE PAYG. How do I get around this? I get the feedback ' 'call has been barred' whenever I try to make one. Any help or feedback would be appreciated.
FYI you have a short time after posting to edit, negating the need for multiple short replies.
@pcarsso wrote:
About 6 months ago
PAYG SIMs require chargeable usage at least once every 179days else they are hibernated for non-usage, with approx 3months grace to reactivate before outright disconnection.
Your symptoms are consistent with this being the cause, in which case your resolution is to contact EE-CS via another means, to request reactivation. You need to call either +44 7953 966150 from any working phone, or +44 800 9566000 from a web-calling app such as Skype.
7 REPLIES 7
If not...On PAYG, roaming is auto-enabled once your phone is used in the UK first. Did you do this?
Northerner
Hi @pcarsso
When did you last make a chargeable call or text on the SIM.
Had you used that PAYG SIM for making calls or texts in UK before going abroad? To be used abroad EE PAYG SIMs need 1st activating on EE's home UK network. If it wasn't you can't now use it until you return to UK.
Yes, I received a welcome message. I will do as you suggest and go through the available local networks. Actually, I have a new phone now. I put my EE sim in it but I have never used it in the UK. I don't know if that is the reason for the challenges
About 6 months ago
Yes, I used that sim back in the UK
@pcarsso wrote:
About 6 months ago
