on 01-10-2024 09:40 AM
Hi there,
I landed yesterday, I purchased the roaming abroad pass suitable for travel to the USA but when I arrived it is just showing SOS, I have restarted it multiple times, my spend cap is now at £50, I have set the networks to manual (none work though), I’ve tried going through EEs AI assistant who told me I have to phone I can’t get passed onto a human guide but I can’t do anything as i can’t even get a signal to phone, it’s a joke
on 01-10-2024 10:56 AM
on 01-10-2024 09:22 PM
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
