‎02-03-2026 02:04 PM
‎02-03-2026 02:24 PM - edited ‎02-03-2026 02:34 PM
@constantin1992 : You'll receive a Welcome text upon arrival at a country giving your roaming options.
If you are on contract, you may use your usual UK allowances in the EE ROW Zone 1 with up to 50 GB data per billing month if you have more, when you buy the Zone 1 Pass for £5 / day or £25 / week or already have it as an Inclusive Extra or you have an EE Full Works or EE Max Plan. Otherwise you will need to pay the charges or buy roaming add-ons as you can find out in https://ee.co.uk/help/mobile/roaming/roaming-costs/.
If you are on contract, just remember to text ROAMING to 150 before leaving UK to ensure the roaming ability is enabled on your no.
If you are on PAYG, just make sure you had already used your PAYG SIM to make a call or text in the UK.
‎02-03-2026 02:06 PM
Hi how much roming to moldova
‎09-06-2026 10:55 AM - last edited on ‎09-06-2026 11:10 AM by Peter_W
Please active my data roaming on other number
[Mod edit - removed mobile number]
‎09-06-2026 11:06 AM - last edited on ‎09-06-2026 11:10 AM by Peter_W
Hi I m in Pakistan please active my roaming data
‎09-06-2026 01:32 PM
@Sardaratiq : Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto.
Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before leaving to go abroad?
If you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
