on 18-02-2025 08:56 PM
Support on USA roaming.
I didn't receive any text when I entered the USA so havnt been been able to set roaming up.
I've been on 5G but have no idea what costs I'm incurring. I thought I had set up roaming a few days ago but when on the bot messaging it said I hadn't.
Concerned I have no idea what service I have what I am paying for. I have had nothing from EE confirming anything or any additional charges.
What doesn't help is they don't have a whatsapp service so I have no means of getting in touch with them since my phone won't send/recieve text and can't make or recieve calls. 😡😡😡
18-02-2025 09:06 PM - edited 18-02-2025 09:07 PM
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. What exactly do you mean by "I've been on 5G "?
