Roaming not working
LucyEE
I bought a roaming pass today and I'm still unable to take or make calls to UK numbers. I'm currently in Montenegro and bought the roaming service so I can make a call for work.
On the app, tells me conflicting informaiton as the AI bot on the help service, tells me I don't have a roaming pass, but the app tells me I do. I have tried removing my spend cap and putting a £50 cap.
I can't ring EE to get help as no calls are going through and there is no one available to talk to via the app.
Please can someone assist? I've been struggling with this for about 5 hours
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
Northerner
Hi @LucyEE
Are you on EE PAYG or pay monthly contract.
  • If pay monthly contract did you activate roaming before leaving the UK.
  • Can you use the internet
  • Have you tried restarting your device.
As you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise as you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
