Roaming in the USA currently not work
Jonathan_L
Currently, this broken for all users on our business account. Raised a level 2 ticket with EE 5 days ago - nothing heard via email as they stated they would do.
Can not make or receive local or international calls despite phone and account correctly set. Have tried all the support requests (switch networks/reset network settings (that lost all my saved wifi passwords - thanks EE))
And in additional the EE website and app are also broken in many places, ie add ons, etc - they are aware of this and have been trying to resolve it for the last 4 weeks. Clearly not acceptable.
Shocking service - going to be taking action on my return to recover costs and make the public aware of their failures.
7 REPLIES 7
An interesting case by the sounds. Had you roamed previously, but are unable to do so in the USA? Or travelled abroad without raoming and requested it added?
A faults case raised by CS should at least be with an offline support team
All handsets were working fine while roaming in April/May/June of 2024 in the US. But handsets now moved from Iphone 13 pro to 16 pros - and now with Esim - although Level 2 support said they are seeing the same issues with normal sims too. You sometimes get the message about 'Spend cap' which is a nonsense as no spend cap set. What is so poor is there nothing on the site to detail ongoing issues with the site or the issue in the USA - they are hiding the true facts for the their customers.
It been escalated to level 2 support at EE- I think we are pass these very simple issues...no disprespect - we look after sites with 20,000+ network devices - we know what we are doing!
This is subtly different to the scenario you initially explained, that a ticket had been raised. Level 2 are just a team within CS, they have access to raise fault tickets into offline (non-CS facing) support teams for anything they can't resolve, and I would expect this to have happened in your case.
There's nothing new about an MNO's website not broadcasting details of known faults to the world at large.
What about web and app working in since they did their upgrade - you can access your account addon via the app or web (if you are small business customer as that fails)  - same with service packs - same with settings!
This has been like this now for 4 weeks - fix was meant to be completed yesterday.
