Roaming in USA
BigCol1980
I arrived in the USA this afternoon. I have not had a text from EE as per your website about setting up the £25 a week roaming pass to use my phone “as normal”. What do I need to do to receive or activate this? Thanks
1 ACCEPTED SOLUTION
