Roaming in USA not working
Stickc
Hi all!
Set up roaming package before leaving UK. Forgot to text roam, roaming not working, can't send text, tried calling from hubby's phone but it just said to text roaming g to 150 which obviously I can't!
Any ideas clever people in my phone?
Posting via WiFi
You may have set up a roaming billing package to help pay for your usage while roaming but that in itself doesn't give your a/c the permission to roam in the 1st place.
You need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
