Roaming in Somalia
Jaamac
Hi there
I’m just stuck I can’t get access into my Roaming can you help
Jaamac
I was expecting a tax message and phone calls from Uk because I think Roaming cap in-active
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
