Can’t receive texts abroad
Nicknat7
Can you make or receive calls abroad? Can you send text messages? Does your phone show coverage of a local network? Have you tried using alternative local networks - what was the result?
Have you been able to receive texts abroad previously? Did you receive the welcome text message on first arrival abroad?
@Nicknat7 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
