on 29-07-2025 08:23 AM
My Phone number will receive texts from my family and some verification codes. but for one of the apps I use, the verification code won't come through?
They said it's a problem with my sim... Is that right and how should I fix it?
Solved! Go to Solution.
on 29-07-2025 11:23 AM
Thank you for letting us know what steps you have tried already.
I would recommend you Contact Us to speak with our tech guides, they will be able to check everything from our side and run through more steps with you.
Ritu
on 29-07-2025 09:17 AM
If you can receive person-to-person texts and some automated messages, then your SIM self-evidently has a connection to EE's network and can receive SMS. It tends to suggest a problem with that specific sender.
Which specific app/service is it that you can't receive from? When did you last receive messages from them?
on 29-07-2025 09:47 AM
The app is discord, I was in touch with their support and they told me to try and restart my phone (In which I did), reinsert my sim (In which I also did), or reaching out to your provider. In which I came here to see if anyone had a solution before I went into a store.
Ritu
