Roaming in Germany
MTaggart
Hi just arrived in Germany and I can’t get a roaming service provider. Don’t normally have problems when in eu
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
@MTaggart  have you enabled roaming on your EE account if you’re a contract customer ?  Have you tried restarting that device?  Have you tried a manual network search ?
