Turkey roaming
Meganbryce15
Hi, I’m going to turkey in may. I have a smart benefit plan and have got the roaming pass but I have no idea if I can use my mobile data while in turkey or if I will have a costly bill at the end of the month. Can anyone help?
TIA
Northerner
Hi @Meganbryce15
Turkey isn't in the EU so your charges are found here under the turkey roaming page:
https://ee.co.uk/help/help-new/roaming-costs/countries/turkey-and-northern-cyprus
Please also ensure roaming and international calls are activated on your account (text ROAMING to 150)
14 REPLIES 14
Northerner
Hi @Meganbryce15
Sal09
I was about to create a new post re Turkey Roaming as we will be travelling to Istanbul end of Feb 22. I rang EE and was advised by a CS if you are going to the European side of Turkey  We can use both our EE plans as per usual. But upon searching the internet I think CS provided me with incorrect info.
Can some one on here please correct me if im wrong or help.
Sal
@Sal09  It’s listed as Turkey so it’s the whole of Turkey.
 It’s only northern Cyprus that you have to be careful when roaming as you could join a Turkish network and you’ll be charged for usage.
Sal09
Thanks @Chris_B
Best and safer option will be to just add Roaming Add On. I think its only £6 per day.
Apologies for the dumb question, just for my understanding and clarity - we WILL need to add roaming to use our phones in Istanbul?
James_B
EE Community Manager
Hi @AminR-89,
Yes, you'll need to activate roaming if you're on a pay monthly plan. (Pay as you go accounts will be ready to roam)
To activate roaming, please text ROAMING to 150.
Hope this helps.
Would you mind sharing your experience with EE in Turkey?
I am on Pay as you go with EE. I understand there’s no chance I could use my UK data in Istanbul like I do in Europe?
Many thanks,
Sol
Jon_K
Former EE Employee
Hi @Sol2022.
Welcome to the community.
You can see all of the rates and the bundles available in Turkey on our EE Roaming Page.
Hope this helps.
Jon
Hi Sol, apologies for the delay in response.
Overall it was good, had 3G/4G signal. Only issue was the limit, I ran out of data every day and came home to a £80 bill!
