Roaming charges
karis6197
Travelling to Dubai on 29 November for  5 weeks so thought I'd look at options for roaming but cant get any sense out of the roaming page. I type in my phone number, where I'm going & how long I'm going for (this seems to be limited to 16  days for some reason) but when I hit search, I don't get the options page! Dubai just disappears & I'm back at square one, locked in some sort of loop, any ideas?
garybs29
Scholarly Contributor
Check under United Arab Emirates for the options as that's the country, Dubai is a city
@karis6197 :You'll receive a Welcome text upon arrival at a country giving your roaming options & the opportunity to buy Roaming Passes.
If you are on contract, you may use your usual UK allowances in the EE ROW Zone 1 with up to 50 GB data per billing month if you have more, when you buy the Zone 1 Pass for £6 / day, £30 / week or £50 / 15 days or already have it as an Inclusive Extra or you have an EE Full Works or EE Max Plan. Otherwise you will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/ > United Arab Emirates.
If you are on contract, just remember to text ROAMING to 150 before leaving UK to ensure the roaming ability is enabled on your no.
If you are on PAYG, just make sure you had already used your PAYG SIM to make a call or text in the UK.
