Roaming from Abroad
antoniospecchia
I'm abroad already and I didn't think I needed roaming -I generally purchase local SIM for that-. Now I need to receive a call from the UK, as I'm experiencing a road accident and the idiots of AA only call you on the UK number.
I went online on EE website and there is NO way to set up a Roaming of change the spending cap. Simply call us: on a UK number.
How I'm supposed to call you to purchase the roaming if I can't use my phone without roaming???
12 REPLIES 12
Your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. The AA is a UK organisation and to expect them to call or provide foreign contact numbers is an interesting view.
Who are you and why reply such useless way?
Assumptions and judgments that are not requested and show you didn’t understand the point.
Have you anything better to do?
Antonio
Written on the move
antoniospecchia
I see, people are here for some sort of benefit from EE.
Two answer two non sense. None of them that really got the meaning, just offering "solutions" to a problem they imagine to have understood.
That's why I don't like the "communities": other users who jump into someone else problems.
I would like to have an aswer from EE to my problem but they do not care to provide a way to contact. Anyone who didn't experience it please stay away.
Whatever you are using to manage to post here can be used for Skype.
Could you please clarify the problem you're seeking help with? It seems to be "I'm abroad without roaming. How can I contact EE to enable roaming?" in which case two responses have given advice.
If we've misunderstood, please do clarify.
You think your situation is unique but it isn't! Join the club of 1000's of others.
NO, the problem is that I CANNOT contact EE.
I went online on EE website and there is NO way to set up a Roaming of change the spending cap. The only option is Simply call us: on a UK number.
The Question was provocatory: they are stupid as they do not enable user to set up roaming and spending cap on the website but they suggest to call them!
this is the point.
Hence the Skype suggestion from both of us.
