24-11-2024 10:58 AM
I'm abroad already and I didn't think I needed roaming -I generally purchase local SIM for that-. Now I need to receive a call from the UK, as I'm experiencing a road accident and the idiots of AA only call you on the UK number.
I went online on EE website and there is NO way to set up a Roaming of change the spending cap. Simply call us: on a UK number.
How I'm supposed to call you to purchase the roaming if I can't use my phone without roaming???
24-11-2024 01:39 PM
As I want to demostrate: EE are a bunch of idiots.
The code never arrive on my mobile as I can't activate the roaming
I'll change company asap
24-11-2024 01:40 PM - edited 24-11-2024 01:40 PM
Download Skype. Call them on the number provided by the guys above for free. Easy.
24-11-2024 01:41 PM - edited 24-11-2024 01:44 PM
You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app such as Skype over WiFi.
There is a natural catch-22 created by being abroad without roaming. As with any catch-22, you need to break it somehow - using another connection to make your contact, is how.
You also refer to "purchase the roaming", which is a popular misunderstanding. The roaming facility is free of charge, and can't be setup online even in the UK - all published advice is to text ROAMING to 150 prior to leaving the UK. You may be confused with a chargeable billing add-on which reduces the cost of using foreign networks.
