Re: Calling UK from spain. Are we EU?
GriffGriff
ROAMING
Katie_J
Hi @GriffGriff.
Thanks for coming here.
Do you have a question on roaming?
Katie
Hi.
Yes.
I don't appear to be able to make any calls to the UK whilst on holiday in Spain?
Sent from Griffs iPhone
Katie_J
Hi @GriffGriff.
Thanks for getting back to me.
Did you activate roaming before leaving the UK?
If yes, are you connected to a local network?
Speak soon,
Katie
@GriffGriff : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
