on 22-09-2024 12:30 AM
I’m in Indonesia for work, and my phone is working fine on the hotel WiFi but I can’t call EE on 150 for any customer support, and my phone doesn’t work at all off WiFi. I have the international passport package on my phone, roaming is turned on etc, and if I try and message 150 to sign up to regular roaming it says it’s failed and I need to call - which I then can’t do!!
anything else I can do? I’m a lone female with a serious medical condition and not having a useable phone whilst I’m away on business is not just inconvenient it’s frankly quite frightening and dangerous.
Thanks in advance for any help - kind of at my wits end here and hoping an e sim might work instead
Solved! Go to Solution.
on 22-09-2024 05:24 AM
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
on 22-09-2024 07:12 AM
Thank you both. I've got roaming activated on my device and EE account I believe as I travel a lot and have only had this problem in Singapore and now Indonesia. I've opted for an esim for now and thankfully that's given me coverage and the ability to call EE, so hopefully I will be able to rectify from there.
Appreciate your advice!
on 22-09-2024 07:55 AM
Data roaming on your device is a red herring. It's possible you had roaming activated on your a/c for the EU but not globally.
on 22-09-2024 08:11 AM
Having a physical SIM from a local operator would have achieved the same end result, as would using a local WiFi connection to use Skype.
An electronic SIM is just a different type of SIM.
on 22-09-2024 08:29 AM
@SML26 , you may need to turn automatic network connection off and do a manual search for a network to see if that works as well.
