Overseas
H-Sp9876
Hi all,
I want to travel to outside the EU, what should I do to keep to be able to use EE with my data plan?
Appreciate your guidance🙏
Katie_J
Hello @H-Sp9876.
Thanks for coming here.
Where about will you be travelling to?
Our Roaming Tool will show all your available options when you enter your destination.
Katie
@H-Sp9876 : Where are you going? Except for 5 specific countries you cannot use your usual UK allowances outside the EU but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/ .
If you are on contract, just remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, just make sure you had already used your PAYG SIM to make a call or text in the UK.
