on 14-10-2024 01:54 PM
I’m in Reunion Island (France in Indian Ocean) without network. I forgot to do the request before I left. No worries I thought, I don’t want to spend my honeymoon on my phone. But my travel cash card is being declined and I have no way of dealing with that or with EE without network to phone anyone. Can anyone please help? I’ve tried all the advice I can find included turning phone off and on again but I have had no text, no reception, no network options at all. How can I get help without being able to call EE?
on 14-10-2024 03:52 PM
