13-10-2024 08:43 PM
It’s unbelievable. I called ee to inform them we were going to be visiting the USA and I would like to adjust our roaming tariff accordingly.
We get to USA and our phones won’t make or receive calls. There no dial tone when I try to call and the call just hangs up before the timer appears or just doesn’t connect at all.
So I can’t even call ee to try and speak to someone. I’ve wasted 5 hours over 2 days messaging back and forth through the app as that’s the only for of communication I have as I cannot make calls. Also made endless network setting adjustments and phone restarts.
Has anyone had similar issues? What was the resolve?
thanks
rob
13-10-2024 09:02 PM - edited 13-10-2024 09:05 PM
@Robbiefarr : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
13-10-2024 09:04 PM
This is a perfect illustration of there being as much confusion from end-users as a process-issue within CS.
You've fallen for the classic misconception of roaming needing a billing add-on, but forgetting to check that the (free) facility to roam in the first-place, is in-place.
CS haven't checked that roaming is enabled alongside your request for a billing add-on.
As for your final question of what the resolution is, almost certainly - enabling the roaming facility. Unfortunately, because you've travelled abroad without enabling it, you've created a catch-22 situation and will need to make contact with EE-CS by another means.
