Best package for using phone in Sri Lanka ?
Shashigupta23
travelling to Sri Lanka for 2 weeks what’s the best add on to use to be able to use phone and internet ?
Outside the EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/srilanka.
If you are on contract, just remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, just make sure you had already used your PAYG SIM to make a call or text in the UK.
