Number converted to eSim. Can't find number on iphone
helpmeEE1
I am abroad and my number is greyed out. I cant use it. how do i fix this?
helpmeEE1
how can we contact if we dont have signal other than wifi? The sim isnt working abroad
Greyed out where? Is it otherwise working abroad?
Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
helpmeEE1
In my mobile settings on iphone it shows my number +44... and below says converted to eSim. If I click on that it says SIM: Status: Inactive, Mobile Plan Label: Primary, My Number: +44..., then a toggle that says 'Use this Line'. Everything is greyed out. No messages can be sent even with wifi. It seems as though it doesn't know the sim card is in the phone
helpmeEE1
  1. I cant make calls, or send SMSs - I cant change. Cant select my phone number on mobile data. it's all greyed out
Does your phone have 2 SIMs? Which are EE?
