on 07-09-2024 03:00 PM
Arrived in US after purchasing Roaming package from EE and receiving a text before I left UK saying everything ready but cannot connect to any network. Tried calling EE several times from my wife’s phone which is costing £1.44 per minute and had no issues connecting to a network but customer services line keeps hanging up. Have tried switching to/from airplane mode, restarting phone and still nothing. My SIM is about 10 years old will this be affecting this? If so why didn’t EE tell me this before I bought the roaming package? Help!,
on 07-09-2024 03:19 PM
Hi @Campbell36
Was roaming activated on your pay monthly contract before leaving the UK.
If not you'll need to speak to EE CS via Skype and WiFi on the number in my signature.
on 07-09-2024 03:38 PM
07-09-2024 04:13 PM - edited 07-09-2024 04:14 PM
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
