on 07-09-2024 08:14 AM
My roaming don’t work Czech Republic I add spend cap 25£ monthly nothing work why can u help me
on 07-09-2024 08:52 AM
on 07-09-2024 09:08 AM
Hi @Pavlina1
If roaming is not activated on your account then you'll need to speak to EE CS. Use the number in my signature over Skype to contact EE.
on 07-09-2024 03:54 PM
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
