16-03-2025 07:20 PM
Hi, please can anyone advise if I can get data on a Norwegian Fjords cruise through dat roaming?
Thank you
16-03-2025 10:17 PM
@Monky : You cannot use your usual UK allowances at sea but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/maritimeshipsferriesandcruises.
When you are in contact with EU shore based networks you may use your usual UK allowances in the EU with up to 50 GB (contract) or 25 GB (PAYG) data per billing month if you have more. If on contract & your contract started after 07/07/2021 there'll be a £2.47 / day charge for using your UK allowances in EU unless you already have the Roam Abroad Pass for £25 / month or already have it as an Inclusive Extra. Alternatively you may buy the 7-day EU Pass for £15.
16-03-2025 10:17 PM
17-03-2025 06:51 AM - edited 17-03-2025 06:52 AM
Typically when you are actually in the Fjords you will pick up the land based networks but depending on how much you are moving around the networks might jump a bit, usually this isn’t an issue.
17-03-2025 08:08 AM
Regardless of which billing option you choose, remember to enable the free roaming facility before leaving the UK. This enables access to foreign networks - which includes the onboard mobile network - and prevents a no-coverage scenario.
Text ROAMING to 150
17-03-2025 07:37 PM
