Romina not working
MariaPau
Hello roaming is not working in Italy
Katie_J
Hello @MariaPau.
I hope you're having a lush time in Italy.
Did you activate roaming before leaving the UK?
Are you connected to a local network?
Did you receive a welcome text when you arrived?
Katie
