‘No service’ in Morocco
CathyStacey
Please can anyone help me. I’m in Morocco (non EU) and I cannot connect my phone to a mobile network. It says ‘no service’ on top left corner of screen. My mobile is completely dead when I try to call 150 and I can’t receive texts which means I can’t log onto anything that usually sends me a security code by text to be able to log on. I can use wifi but that’s it. Any suggestions as to how I can reconnect my phone? I’ve tried all the usual methods. Thank you
1 ACCEPTED SOLUTION
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks..
@CathyStacey : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
