on 07-10-2024 03:36 PM
I’m going to Greece towards the end of the month and intend to get a Roam Abroad Pass.
Can I use my phone as a WiFi hotspot for other devices, or will I be charged? (I’m sure I’ve heard of charges before when doing that, maybe another network).
Solved! Go to Solution.
on 07-10-2024 06:47 PM
Hi @Andy410
Welcome to the community 😊
Ahh, I bet you can't wait to jet off to Greece!
If you're headed away for a couple of weeks you're doing the right thing by adding the Roam Abroad Pass. You'll not be charged anything extra on top of this for using your phone as a Hotspot.
Just be mindful that if your plan comes with more than 50GB of data per month, a fair use policy of 50GB will apply when roaming abroad.
Our What should you check before travelling? page will also give you some great tips before heading away.
I hope this helps,
Linzi
Hi @Andy410
I hope this helps,
Linzi
on 07-10-2024 07:02 PM
Hi Linzi,
Thanks for the information 😁
Andy
