Mobile Calling not working in Australia?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-05-2025 10:28 AM
I upgraded to the sim plan I had on my Samsung phone to "Full Works SIM" which is £53 per month, as I was promised it would work for calls and data in Australia.
I have arrived now in Australia, and haven't been able to make a single phone call all day. The phone doesn't even ring! I did receive a text from EE advising I can use data and calls, but I am only able to use the data. For whever reason calling doesn't work.
I have increased my spend cap - and on the way to Australia, my phone worked perfectly fine in Singapore. I have tried aboslutely everything on my mobile phone to get it to work, but to no avail.
My wife is in the exactly same predicament, with her apple phone. And she gets data but no calls at all.
This can't be an isolated incident as we are both independantly on separate plans and mobile devices. Is there any resolution at all for this?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-05-2025 09:57 AM
I am experiencing the same issue. Internet works, but the phone doesn't even ring when I try to call.
Was in singapore yesterday and everythhing was working perfectly. Please does anyone have any idea how to resolve this?
I attempetd to cycle through networks, but to no avail. Phone just does not ring. I can't call EE because phone doesn't ring and they are in UK.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-05-2025 10:13 AM
Your post has been moved to a new thread.
Can you send & receive text messages? Is there any difference in behaviour with calls, depending whether the number you're calling is in-country or international?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-05-2025 12:15 PM
Hi @Allon1us
Welcome to the Community
Are you able to manually connect to the Telstra network?
To manually select a network on an iPhone, navigate to Settings > Mobile Service > Network Selection, and toggle off the automatic selection option.
For Android phones it's settings > connections > Mobile networks > Network operators
Ali
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-05-2025 02:14 PM
Hello, thank you for your reply.
I had not experienced a difference. Its a long quiet attempt at making a call, and then the call drops. I have read up on Australias phasing out of the 3g network to call, and move to VoLTE networks middle of last yeat. I trust this may underly some of the issues.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-05-2025 02:37 PM
Hi Ali, thank you for the reply. I have had some partial success.
I looked at my network options and only had one option "optis" which I found quite peculiar, as it should have more options.
I changed my network mode from 4g/3g/2g to 5g/4g/3g/2g, and then Telstra and Vodafone appeared (both of which were not there before). I then connected to Telstra and attempted to call an Australian number and it rung. I was overjoyed, as this had not happened before, but am now faced with another problem - and that is getting my wifes apple phone to work as well.
I got her on the Telstra network (as on her mobile the options are 5G auto, 5G on, and 4G), and she is able to call me off her mobile, which I receive when she dialls my UK number from Australia using the +44 prefix, but it goes straight to missed call if she doesnt use the prefix.
When calling her now as both of us are on the Telstra network, something bizare happens. There is a silence on the line and after a while it says "...E voicemail, im sorry but the person you called is not available. If you would like to leave a voicemail". It cuts off straight to her voicemail without her phone ever ringing, and shows my call immidiately as a missed call on her mobile with no caller I.D.
I guess the new uqestion is - how can a UK EE number on an apple device receive calls, when on an Australian network - as these all drop off and go straight to voicemail, leaving the user eith a missed call, and the line never ringing?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-05-2025 03:12 PM
I can't directly answer that, but the call flow for these calls would be...
Calling phone <---> Local radio <---> Local core routing <---> EE-UK-core network <---> Local core routing <---> Local radio network <---> Called phone
Thus the reason is likely to be in the central/routing networks somewhere.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-05-2025 03:28 PM
Thank you Bristolian,
I am trying to understand myself as the setup now should in principle work.
My EE android phone -> Full works Sim -> connected to Telstra
My Wifes Iphone -> full works Sim -> connected to Telstra.
Apple to Android calls will start ringing and work.
Android to Apple calls go straight to voicemail and fail to ring.
I have tried toggling a few settings on the Apple phone, but seems to have made no difference:
1. Data mode: low data or stabdard gave same outcome
2. Wifi calling - made no difference
3. Calls on other devices - this option also didnt affect apple phones ability to receive calls
I am running out of ideas of what else to possible toggle or try - and am open to any thoughts
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-05-2025 03:44 PM
I'll take WiFi-calling as a good example of where confusion can often result. This does not mean using an app to call as is often mistaken, but uses the phone's normal dialler & menus to send & receive texts, make & receive calls with the WiFi-signal replacing the network one. In technical terms, the core network remains the same but the access layer changes.
It's meant as a coverage enhancement in the UK, isn't supported abroad but can sometimes work. To illustrate my point, the cal flow for any UK call would be...
User device <---> Radio access layer <---> Core network <--- onward routing. Thus whether that radio access layer is WiFi or mobile, makes no difference to the routing otherwise. It's what enables handovers between VoWiFi & VoLTE.
I'd be tempted to 2way SIM-swap between the Apple & Android phone, to be sure the issue remains with the device itself. The "data mode" would be irrelevant, neither VoLTE nor CSFB (fallback to 2G/3G) use data.
With Android > Apple calls failing to EE voicemail, that tells me the call is failing to setup on the receiving side.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-05-2025 04:12 PM
Thank you once again for the response Bristolian - its insightful.
I keep thinking that the other variable is that I have a physical sim card, and my wifes iphone 16 had an eSim. And whether the fact she has an eSim is preventing the reception of the calls. Are they regionally locked, compared to traditional Sim cards?
