I renewed contract said I will still get free eu but in Holland no free eu roamd
Scottceltic1
You've put part of a question in the subject line, but left your post blank.
Can you explain your query fully, use the "reply" function and put your question in the body of your message. It sounds like you've got a question about EU roaming - Holland is in the EU.
Northerner
Hi @Scottceltic1
Did you ensure roaming was activated on your account.
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
