I’m in abroad now how can I activate my phone calls cz I will get some calls
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-11-2024 02:32 AM
I’m in abroad now how can I activate my phone calls cz I will get some calls From uk it’s important
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-11-2024 02:37 AM
@Humaira22 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-11-2024 02:37 AM
