on 14-05-2025 01:42 PM
I cannot make calls or send texts abroad
on 14-05-2025 01:58 PM
@srailclhya : Did you receive a Welcome text upon arrival?
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
