Hi, I can't call.
nowkawa
I am using an OPPO phone in China, but cannot make calls to Chinese phone numbers. It says that calls are restricted and text messages cannot be sent. The UK number has enough balance. Please help me solve this problem. Thank you very much.
7 REPLIES 7
Northerner
Hi @nowkawa
It maybe local restrictions.
If you're on PAYG try adding the area code to the number you're calling.
What does PAYG mean?😅
I called EE customer service from my local number in the UK, but the call was not able to go out. I used my Chinese number to call the UK, and the call fee was higher.
I live in Wenzhou, Zhejiang, China, and the 4G network has full signal. Others can use it normally, but I have a problem. Thank you.🤝
@nowkawa , PAYG is pay as you go, instead of a contract with EE.
I've contacted the customer service and I'm waiting in line for a long time. Please help me activate it. Thank you very much🤝
@nowkawa ,we cannot do this in the forum, you will either have to go to an EE high street store or ring customer service and press option 2, should get you through to one of the guides. You can only activate it in the UK, as if you did not activate and make a chargeable call or text whilst in the UK there is no way to do it.
You can otherwise send the SIM card back to the UK to someone you trust, who can make a chargeable call or text and that will activate it and then send it back to you, as all SIM cards need to be activated in the UK first, as it is a UK network card.
