ā05-04-2025 01:54 PM
Can I talk to someone
ā05-04-2025 03:07 PM - edited ā05-04-2025 03:08 PM
@Alibali223 : Can you make calls & texts?
ā05-04-2025 01:51 PM
How do I get onto live chat
ā05-04-2025 01:52 PM
ā05-04-2025 02:48 PM
Hi @Alibali223
Download Skype and use WiFi and the number in my signature to contact EE.
ā05-04-2025 03:20 PM - edited ā05-04-2025 03:21 PM
Connect to WiFi and use Help in the EE app.
