Help desk
Andymoo
I need to speak to someone about my network says no service, Im on holiday purchased a 7 day pass and it didn't work, when I phone up to cancel it a few days later and asked for it to be taken off, it cut off and never worked since, could u help please
1 ACCEPTED SOLUTION
@Andymoo : Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto.
Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before leaving to go abroad?
If you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
