EU signal and costumer service from abroad to UK so bad ,auful
eirinageorgieva
I have had the same problem for months, and they haven't fixed anything. It's frustrating. The problem they don't fix is nothing terrible
No signal
Northerner
Hi @eirinageorgieva
  • Which EU countries.
  • Are you on EE PAYG or pay monthly contract.
  • What device are you using.
@eirinageorgieva : Did you receive a Welcome text upon arrival?
