The content you are looking for has been archived. View related content below.
30-07-2025 11:05 AM - edited 31-07-2025 11:36 AM
If you’re going abroad soon and want to use your device for calls, texts and data, here’s everything you need to know.
If you have a pay as you go SIM, please make sure you use this within the UK first before heading abroad to activate roaming. This includes making a call or sending a text whilst connected to the EE Network.
If you're a pay monthly customer, you’ll need to make sure to activate roaming.
Follow one of the steps below:
It can take up to 24 hours to activate on your account, so it's important to set it up before you travel.
For the most accurate information for your contract, follow one of the steps below:
If you wish to access your voicemail messages when roaming, here are some great tips:
To check potential charges for using your voicemail abroad, please visit our Roaming Costs help page.
The EE fair use policy includes you being a permanent resident in, or having a stable link to, the UK. We will consider you to have a stable link to the UK if, during any four-month period, you:
Full information on stable links can be found in the terms and conditions.
If you have any questions, tap 'Reply' below.
22-07-2026 02:33 PM
I want the opposite, why are there no help articles about this? I want to turn OFF all mobile data when I'm on holiday. I do NOT want any possibility of charges for calls, texts, or connecting to a network abroad. I ONLY want to use wi-fi. Can someone please give a simple solutions for this?
Should I just use airplane mode? But if I had to restart my phone, for example, airplane mode will turn off. And I've heard people say that even with mobile data and roaming turned off, they still got charges.
Please give me a clear and simple answer.
22-07-2026 03:15 PM
Welcome to the Community, @SuzBanes
Airplane mode is a great way of totally preventing any roaming connections going through your phone, but there are a few other options you can look at too.
The exact way to do this depends on your phone model, but many phones will have an option to block data roaming in your connection settings.
Another option is our spend caps - if you set this to no spend, it will stop the daily EU charge for roaming, but not prevent you opting into a pass.
Both of these options will only stop you getting online though, and will not block calls or texts.
Finally if you give our customer care team a call, they can fully disable roaming on your account, which would 100% prevent your phone from being able to connect to an international network.
Peter
