Can’t connect to network in Australia
DGK1
Hi I can’t access text, make calls, or access internet (except through WiFi) despite having roam abroad and also having purchased additional minutes to allow me to call when not in Australia…I’m travelling on to Japan. I have switched off phone, tried to access networks manually but all I get is SOS. I have tried to contact EE but the bot pretty unhelpful and have waited 3 hours to have my query dealt with. I can’t access work emails as it requires a passcode via text etc…feel a little let down by EE and also that I must be a tech failure :-). Urgent help would be appreciated.
@DGK1 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Hi
Unfortunately despite calling EE I bought a vodaphone sim in Aus problem not sorted. Have given up and will try and sort when I get back to UK…must be some simple script gone ary.
Sent from Sky Yahoo Mail for iPhone
Leanne_T
Hi there @DGK1
Thanks for coming back to us.
I am very sorry this was not resolved for you and hope you are having a lovely time in Australia and when you travel to Japan. The trip sounds amazing!
Did our mobile guides get the account looked into to make sure your roaming settings were correct when you called?
If you have a chance when roaming please call us again or when you return to the UK to see what is needed to use the phone abroad to make sure this doesn't happen again.
Thanks 🙂
