Can't call from Switzerland
d5222
Received the confirmation text that I can use my minutes to call in the EU and UK same as when I'm in the UK. However, no calls are going through. Please advise!
6 REPLIES 6
Schockwave
Hello @d5222 ,
\Welcome to the community,
Did you activate roaming on your account? This would only need doing if on contract, pay as you go are automatically enabled.
Did you receive the welcome message from EE/
If yes to both, have you tried a manual search, there should be no reason why you cannot get a network there, I should know I have been there.
If you did not activate roaming on your account, then you will need to call EE using something like Skype for free with the free number to activate it.
Hi
Roaming is enabled on my account and I have done so before in the EU. I got the confirmation text when I landed and it says my phone is set to roam in Switzerland. Weirdly, my 4G is working perfectly but my calls inside Switzerland and to the EU are not working and an automated voice says ‘your connection is blocked for this destination’.
I will try revolving through the carrier options to see if that resolves it.
Many thanks
Can you clarify what you mean by "my 4G is working perfectly"?
Try manually swapping between local networks, check if the symptoms are the same or even if the voice differs. This will ID whether the problem is specific to the Swiss network, or more general.
Thanks. I mean that my data allowances for going on the internet is working well, I just can't place phone calls.
The different Swiss carriers all have the same problem.
Katie_J
Hi @d5222
Thanks for coming here.
Are you aware of anyone else experiencing the same?
Katie
