13-02-2025 03:49 PM
I have a full data roaming package purchased for the USA but am unable to make any calls or text messages. Have checked all settings and but can’t make or receive any calls or messages that aren’t over WiFi. I can’t call 150 for help and this is the only messaging service I can find. Are there any options to contact ee for a live online chat to resolve this?
13-02-2025 03:59 PM
13-02-2025 03:59 PM
