Can't Roam HELP
mE8419
Hi
I have a full works SIM only contract which includes roaming everywhere. I am currently visiting USA and I can't make any outgoing calls but I can use my data and tx.
I have tried all the correct codes to call out and even changing my spending cap higher in case this was the issue but still nothing a call just doesn't connect.
Please someone sort this as I need to make calls while I am away.
Leanne_T
Hi there @mE8419
Thanks for coming back to us.
If the signal drops when roaming, this could be a loss of service on the roaming network and a restart can help you get connected.
If this continues, you can get in touch with our tech guides and they can check everything at our end for you.
Leanne 🙂
12 REPLIES 12
Northerner
Hi @mE8419
What device do you have and is there a roaming setting under settings.
Are you using international codes when trying to call.
Can anyone call you.
Hi
I am using vivo x100 pro. I have data roaming on under settings. I don't see any settings about calling out.
Yes I have tried the international code and without no matter what I try the call just stays silent then ends
Matt_124
Try switching networks via a manual network search in your settings.
I believe AT&T was the one that some people switched to and it worked, but this may have changed.
This sounds very much like a VoLTE issue, swapping networks manually should indeed be the way to go. At the very least it will remove another variable.
I restarted my phone and so far it has worked I can call out. Not sure what the issue was but if it happens again I shall post back.
Cheers for the suggestions and help guys fingers crossed it's finally sorted
Hi
Your spot on. I restarted my phone and I suddenly could call. The only thing that changed was the VoLTE symbol appeared. (I have this ticked on as standard).
Unfortunately the symbol has disappeared again today and I can't call anymore. This is very frustrating as I shouldn't have to keep restarting my device when I want to make a call. Never happened on my previous network.
I tried selecting another network manually but it just said no service.
Abu suggestions for a permanent fix?
Cheers
Leanne_T
Hi there @mE8419
Leanne 🙂
Whilst valid advice, I don't think there's anything the frontline agents can realistically do here, if anything they could break a setting that's self-evidently already working.
This scenario likely needs a fault ticket raising to have network-level roaming config checked over. The fact that a restart resolves it for a short time before subsequently breaking, proves user-level config as being spot-on.
Might also be worth checking which local network you're connected to when you have problems calling/VoLTE drops, and which you connect to with a restart. If it's the same one, I'll repeat the advice above. If it's different, then your auto-selection is preferring a network that evidently has VoLTE-roaming issues - you may be able to use manual selection as a short-term workaround.
Leanne_T
Hey @bristolian
Thanks for replying and for the feedback.
Our tech guides can raise a ticket to be investigated by the relevant support team, if needed, after completing some troubleshooting.
Thank you 🙂
