‎24-11-2025 04:36 PM
Why can I not call UK from abroad, I can't dial 08,07 or 150,
Assistant please EE,
‎24-11-2025 06:46 PM
Hi @AnnaOj,
Welcome to the EE Community
I am sorry to hear you are having an issue calling the UK from abroad. +44 (0)7953 966 150 is the number to call us on when outside the UK, have you been able to test this one?
The age restriction setting is separate so should have no effect on your ability to use your phone abroad. What exactly happens when you try and call, do you get a recorded message for example? Are other services like your incoming calls, texts and data working abroad ok?
Have you tried changing to another available local network to see if you are able to make a call?
We don't have access to your account via these forums to help directly or arrange call backs from our customer service team.
Alex
‎24-11-2025 05:00 PM
Hi @AnnaOj
Are you on EE PAYG or pay monthly contract.
If pay monthly did you activate roaming on your account. If not you'll need to speak to EE CS directly.
https://ee.co.uk/help/contact-ee
‎24-11-2025 05:17 PM
Thanks for the reply. I'm on a monthly plan which I can cancel anytime, not sure which bracket that goes under.
I believe the problem arose last week when an EE member of staff unlocked the age restriction on my account.
I can not call EE via 150 so need a member of staff to call me back,
Regards
‎24-11-2025 05:21 PM
Yes roaming is activated
Hi @AnnaOj,
Alex
‎24-11-2025 06:51 PM
You mention problems calling numbers prefixed 08 or 07. How about UK landlines prefixed 01, 02 or 03?
‎24-11-2025 06:54 PM
When I try to call, there is no ringing, no connection and after some minutes the call ends. Tried the number above, that doesn't connect either.
Texts and data are working, will try switching to local network
‎24-11-2025 07:40 PM
Yes managed to sort out the problem by switching local network, finally.
Thanks for the replies,
Regards,
‎25-11-2025 08:43 AM
Thanks for keeping us updated with this @AnnaOj
Glad to hear manually swapping networks has fixed your issues.
Ali
