Data Roaming in Singapore
Sam_UK200
Hi Everyone,
I cannot access my mobile data in Singapore even after paying for roaming (£25.00 for seven days). Data Roaming is switched on.
I have tried all the online 'Fixes' such as turning off the phone etc. Nothing seems to work. Any help with would be much appreciated. Many thanks!
1 ACCEPTED SOLUTION
@Sam_UK200 : Can you make calls & texts?
Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before leaving to go abroad?
If you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
The previous reply has alluded to this, but can you be more specific about what exactly "all the online fixes etc" includes?
Have you tried manually connecting to all available local networks rather than using auto-selection? Does "nothing seems to work" mean that you can't make or receive calls as well? Can you send & receive texts? That includes the welcome text message you should receive on arrival, which is also a good test of whether your roaming facility is active.
