07-07-2025 05:06 PM
Hi there I wonder if you can help . I am on a business plan and am going to turkey in August . What’s is my cheapest option to be able to use my usual inclusive data please? Many thanks
07-07-2025 05:48 PM - edited 07-07-2025 05:49 PM
Details on EE Business roaming plans are at https://business.ee.co.uk/help/network-and-coverage/roaming/
Much of the advice posted on this forum is consumer-oriented, the above link has a lot of info. The one bit of advice common to both, is to ensure roaming is enabled on your SIM before travelling abroad - crucial to having coverage.
This is usually done by texting ROAMING to 150.
07-07-2025 10:19 PM
Many thanks , I have looked at this but it’s not making much sense to me . I’ll have a better look and hopefully figure it out . Thanks again .
07-07-2025 10:37 PM
Following the "roaming options for your destination" & "start or stop a roaming plan" links.. And knowing that Turkey isn't in the EU...
I suspect the "Business Daily Passport" will be the obvious solution. Many options will also depend on which specific plan you're on - something only you & CS will know.
07-07-2025 10:44 PM
Thanks very much . Much appreciated 😊
