150 or customer
Gsq
I can’t make a call to 150 through my mobile , or other number. Now I’m in turkey.  Very frustrated.  Cos I can’t check my cap etc.  thanks !
Schockwave
Hello @Gsq ,
Welcome to the community,
Are you on pay as you go or monthly contract?
If on contract, did you enable roaming on your account?
If on pay as you go, when did you last make a chargeable call or text?
You can make a call using something like Skype, see my signature.
Schockwave
Hello @Gsq ,
@Gsq : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
