roaming from Brazil
Matogrosso
I need to make two phone calls FROM Brazil to the UK. What Roaming do I need?
James_B
EE Community Manager
Hi @Matogrosso,
Are you in  Brazil and looking to make a call to a landline or mobile back in the UK?
If you are, you can view the rates here.
There is no special roaming add-on for you. You need to top-up to be able to make calls at the standard rate of £1.80 / min.
IGNORE the 2nd part of my previous post. I got mixed up with calling from UK.
Thanks very much for replying to the question.
I have 5 pounds credit and phoned the number with the correct codes  (it its a n NHS number) but unfortunately it didn't work.
Katie_J
Hi @Matogrosso.
Is it an 0800 number you are trying to call?
Are you able to call any other UK numbers?
Katie
