Will my PAYG SIM card work in Greece?
thebryanagram
I bought a £15 pack on a new SIM card in June, which I used in the UK for 3.5 weeks on a trip before returning to Canada (where I haven't used the SIM card). The pack has expired, but I'd like to add a new pack to the same SIM card before I travel to Greece (direct from Canada, without a stop in the UK) in a few weeks. From what I've read here, I think I should be able to roam in Greece using this SIM card since it has been used in the UK (once I add a new pack to the card), but I'm not sure if I have to use the new pack in the UK before I go to Greece, or whether it's sufficient that the SIM card itself has been used in the UK before. Any help would be greatly appreciated!
Yes, it should work as the PAYG SIM, not the pack, has already been used in the UK.
Just top-up with £15 just before you need it & the same pack should auto recur on it.
Thanks so much!
