on 16-07-2025 04:23 PM
I've just topped up a new PAYG SIM with £10 of credit, but realised I should have set it up on a £10pm plan instead (i want to use it in an old mobile wifi dongle for data only. How can I use my credit against the plan?
Solved! Go to Solution.
on 16-07-2025 05:22 PM
@RobF1972 : Text PLAN10 to 150 to buy it from your credit.
16-07-2025 05:05 PM - edited 16-07-2025 05:05 PM
Do you mean one of the plans seen HERE or do you mean a Pay Monthly Contract?
If it is one of the Pay As You Go plans from the link attached, then pop the SIM into a phone and text ALL PACKS to 150. Your options will appear in the response, and you can then choose PACK10 for a £10 Pack.
on 16-07-2025 06:30 PM
Sorted, thanks.
on 16-07-2025 06:33 PM
