Sim card which doesn't need monthly top up
LadyDalmar
Hi
I need a SIM card for a vehicle gps tracker. It needs to be one I can purchase some initial data and then just leave it in the tracker to dribble down bit by bit over many months rather than any kind of rolling payment or the sim stopping working after 30.days .Does this kind of Sim card still exist with ee? I am a customer so happy to pop it in my phone every x days to make a quick call to keep it going.
Seems I need something very old school that I can't quite get my head around if it still exists! Cheers.
9 REPLIES 9
Katie_B
Hello @LadyDalmar
Welcome to the community.
The SIMs that are offered on EE can be found HERE
These include, Data SIMs, SIM Only and Pay As You Go.
Katie
You could buy a PRELOADED DATA ONLY SIM
Thank you Katie_B .
I had found these earlier but my question is that I need a SIM where the data etc does not expire after 30 days. One where I can do an initial top up of perhaps £5 or £10 for x amount of data , pop it in the tracker and then every 3 or 6 months ( depending on the terms) take it out, use it iny ee phone for a single text or call to keep it 'alive' and then put it back in the tracker.
Does ee have this kind of SIM?
Hi
These only last 30.days.
Look at the 2nd column for 90 days.
Data will always be time-limited. With all PAYG SIMs from EE itself data nearly always lasts for 30 days with a few lasting 90 days as I pointed you at.
Otherwise look on Amazon or other online retailers for EE Connected Data SIMs which could last up to 1 year.
Aisha_959
I need to top up my SIM card with 50 gb
Rach_H
Hi @Aisha_959,
Welcome to the Community!
We offer a range of options to make topping up your phone as simple as possible. Check out our Top Up page.
Rach
@Aisha_959 : What does texting AL to 150 from your no. fully report verbatim (it is free)?
